400EX starter/battery problems
Old May 5, 2013 | 12:40 PM
jwaller21's Avatar
Default 400EX starter/battery problems
I have an 07 400EX and its not charging the battery at all, does that mean I need a new starter? Im guessing the alternator comes with that.
Old May 6, 2013 | 11:43 AM
Neverdone's Avatar
You mean stator???
Are you sure it is not the battery is bad? Jump the quad and unhook the battery and see if it stays running. If the stator and stuff are working it should run with out the battery. If it stays running check the voltage on the battery cables while it is running with the battery unhooked. All the charging equipment running correctly should put out around 13.5 volts at an idle or slightly over idle.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
