Honda ATC 110 3 Wheeler Piston Ring Question
Old 06-09-2013, 11:36 AM
Clueless Kid's Avatar
Default Honda ATC 110 3 Wheeler Piston Ring Question
Hi.
This is my first post here, but I SERIOUSLY need some help.
My Dad and I have been trying for at least 2 months trying to compress these dang piston rings to get them into the head or jug or what ever it's called.
We tried everything from a ring compressor to a hose clamp to just trying to hoax it in with our fingers and some screwdrivers...
What are we doing wrong?
Please help.
Thanks
Old 06-10-2013, 08:40 PM
papa hogg scoot's Avatar
Is your atc cylinder tapped at the bottom? should be.....If you have the oil ring expanders aligned correct and not overlapping at the ends and oil rings in the groove of expanders or rails..then shouldbe fairly easy to get them compressed..I always use my fingers by pinching the ends to the inside an goes in with ease if the expanders or rails are not overlapped each other..So IMO double check the ends of oil expanders or rail some people call them...Good Luck
Old 06-10-2013, 09:56 PM
If I am reading this correctly, then yes. Everything meets your specifications. I'm not 100% sure what you mean by 'tapped', but I think I understand most of it...
This is my first real project, so I may not understand everything. xD
So, Dad said we forgot to size the rings...I could of sword we did, but I guess we didn't...
We'll give it another go and let you know.
Thanks a lot for your help by the way!
Old 06-12-2013, 09:36 PM
I meant tappered at the bottom>....
Old 06-13-2013, 09:04 AM
That's what I thought.
I haven't had the chance to go out and work on it recently, but I'll let you know when I do.
Thanks for the help
coldnorthpol
07-14-2015 11:22 PM
Mojave250A
Ask the Editor
07-12-2015 09:10 PM
Mojave250A
07-11-2015 10:38 AM
200es
07-10-2015 09:09 AM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: Honda ATC 110 3 Wheeler Piston Ring Question
