ES shifting problems
Old Nov 4, 2013 | 04:23 PM
ROWALKER's Avatar
Default ES shifting problems
Have a problem with my 2004 Honda Rancher ES, 350. I ride it daily working in the yard and hunting. Have been having occasional problems for several months, but recently it has been getting much worse. I can be in any gear and for no reason it fails to shift ( up or down) and the indicator starts flashing. I can normally clear it by switching it off and restarting it, A couple of times I have had to manually shift to get clear it. Battery is good.
Anyone have any good ideas as to the cause of the problem and suggestions for a fix. Thanks
Old Nov 4, 2013 | 06:08 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Angle sensor is the most common problem with these atvs
Old Nov 4, 2013 | 06:10 PM
Loved
Community Favorite
Fiche Parts
Old Nov 4, 2013 | 06:12 PM
Loved
Community Favorite
Item number 22 in photo is angle sensor in front engine case cover,,Can order from these guys great people.
Old Nov 5, 2013 | 03:22 AM
Although the angle sensor is the most common cause of trouble, on an 04 the shift motor could be getting worn. Before buying a new sensor check how many times the gear indicator blinks quickly before pausing. It is three times for an angle sensor, I can’t remember off hand what the other codes are.
Old Nov 5, 2013 | 07:14 PM
ROWALKER's Avatar
It blinks twice. How / where can I find out what this means?
Old Nov 6, 2013 | 12:52 PM
According to the workshop manual, fault code 2 is the shifting buttons on the handlebars, or the wiring to them. That is an odd one, I have never had that code as faulty switches do not usually show up as a code. Why, - because if the button does not contact when you press it, the ECU doesn’t know you have tried. I think some codes are complex i.e. two long blinks, pause, four short blinks, long pause then repeating again. So be sure it is definitely code 2 before ordering a new switch.
Old Nov 6, 2013 | 08:00 PM
Loved
Community Favorite
I had codes #2 and #6 the other day an was an bad angle sensors..Just have to check out everything..
Old Nov 6, 2013 | 08:36 PM
ROWALKER's Avatar
Thanks for your replies,. I think I will get an angle sensor and try it. Will post back in a couple of days if it doesn't help. From what I have read this is a easy install on the 2004 model, not like some others that require a preload sequence???
Old Nov 10, 2013 | 08:46 PM
ROWALKER's Avatar
My problem has gotten worse, it will now only shift from N to Rev and back. Has stopped flashing error codes.
Got a new angle sensor and replaced the old one. No change, will still only go in reverse and does not flash codes.
