Honda stalled and won't start
If it just died while running at full throttle, it could be electrical. If you sprayed starter fluid or primed it some other way and still no hint of kicking over, then I'd suspect electrical. First, replace the plug. Just because it sparks when you remove it and ground it against the block, doesn't mean it will spark under compression. It's a cheap thing to change out. Then second, check all you wires where they rub the frame. One could have worn through and is grounding out. Especially if it's the kill switch wire.
#16
Yes. I hadn't thought of that. BUT, if the chain was still on the cam gear, even if it had jumped a tooth or 10, I would think that the engine would pop once in a while due to the fact that it would still be getting gas and spark and sooner or later, the gas would explode. OTOH, if the chain broke, then there would be no pop, ever.
#18
Have one timing chain on camshaft which works both rocker arms I would prolly check compression then see what its readings then if ok then remove value covers and get engine TDC an inspects values and rockers to see they are moving,If was running at high speed could have jump time or floated an value [bent] value or rocker nut came off, Then inspect TDC with cam timing and crank timing on flywheel to see if engine still in time
