Honda stalled and won't start
Old Feb 6, 2014 | 07:48 PM
  #21
ATVnoobie's Avatar
Ok I'll have to find them, and check it. I got a tester for the compression but the smallest threads are a 14mm and I think my plugs are 12mm so I'm going to have to get an adapter to go from 12mm to 14mm
Old Feb 7, 2014 | 05:21 PM
  #22
ATVnoobie's Avatar
Well it's in time and has good compression, so I am going to get a new cdi to make sure it's firing right
Old Feb 8, 2014 | 12:43 PM
  #23
If you are getting a spark, it is extremely unlikely that the CDI is faulty. Clean the carburettor out, it is easy, cheap and probably what is wrong. The ignition timing is controlled by the module on the outside of the flywheel, and unless either the module or flywheel is loose, the ignition timing will not alter.
Old Feb 8, 2014 | 02:15 PM
  #24
ATVnoobie's Avatar
Can you ohm a cdi? I have already cleaned the carb 3 times.
Old Feb 17, 2014 | 01:59 PM
  #25
ATVnoobie's Avatar
Clean carb, gas reaching carb, blue spark from new plug, good compression(checked when I put engine on TDC) it's in time, valves moving when engine turned over, getting air,what could possibly be keeping it from even trying to run? Also I need to know how to set the idle and fuel/ air screws.
Old Feb 17, 2014 | 02:07 PM
  #26
budedm's Avatar
Clogged exhaust? Mouse nest in it?
Old Feb 17, 2014 | 02:11 PM
  #27
ATVnoobie's Avatar
I can feel some presure through exhaust when the engine is turned but ill check that
Old Feb 17, 2014 | 04:01 PM
  #28
ATVnoobie's Avatar
Exhaust is clear, kill switches are working right
Old Feb 17, 2014 | 08:06 PM
  #29
nachop's Avatar
Have you tried spraying some type of starting fluid (WD-40 works great) into the back of the carb while holding the throttle partially open and cranking the engine? Just because you are getting gas to the carb does not mean you are getting gas to the engine. Compression is checked with a compression gauge while turning the engine over.
Old Feb 17, 2014 | 08:11 PM
  #30
ATVnoobie's Avatar
Yes I have used starting fluid, only loud backfires. Yeah I know but my gauge doesn't fit, I just know when I checked its timing it would turn easy then get harder, then turn easy again, I could tell the piston was compressing
