Rubicon Front Differential
Old Apr 1, 2001 | 11:02 PM
Andrew84's Avatar
Huh.. what's up with that? Everything I read about the new Rubicon said it has the same diff. as the Rancher too. So what whould happen if you lifted a Rancher off the ground and grabbed a wheel?
Old Apr 1, 2001 | 11:20 PM
Michael2's Avatar
Sapo,
I don't own a Rubicon however I did see this occur while I was test riding one at a dealership. I would currently own one if it weren't for this feature, I too read all the reviews and when describing the differntial they all use words like: great, steller,awesome, one of the best in the industry but they never say it works. Now I actually have the Rubicon literature here and it states "It's full-time four wheel drive features a torque-sensing front differential that substantially reduces torque steer" I guess it doesn't say it works either. Anyway I hope you like it, I know I do.
Old Apr 1, 2001 | 11:31 PM
TEXMud's Avatar
Andrew84, my Rancher does the same thing.
Old Apr 1, 2001 | 11:56 PM
redrubi01's Avatar
if ur ever goin up a short incline or get stuck in some mud.... pump the front brakes a couple of times and that will engage the tire that is not spinning.. that is all i have to do to my rubi.. so i will talk to ya later
Old Apr 2, 2001 | 11:11 AM
  #15
Sapo's Avatar
redrubi01,
Does pumping the front brakes give a different effect than just grabbing the front brake and holding it for a few seconds? I tried that while climbing an incline and the tire would "twitch" right when I applied the brake but then just sit there. I could feel it try to pull me up when that tire would try to catch. If it would have pulled, the bone stock '86 Fourtrax 4x4 wouldn't have made an *** out of the Rubicon like it did. With ALL four tires pulling it walked straight up the bank.
Old Apr 5, 2001 | 09:52 AM
  #16
sxr6's Avatar
To 2000 Mojave; What do you mean FIRST TRUE 4WD, my 89 suz has front diff lock for true 4WD. My 2000 300 Cat also has front diff lock for true 4WD.
Old Apr 6, 2001 | 07:10 PM
  #17
ctebbe's Avatar
Sapo,
Wait until the Detroit Locker from Highlifter is released and then replace that front differential. Thats what I an going to do with my 450S. I hate that 4x3 that it has now.
Old Apr 6, 2001 | 08:05 PM
  #18
boots11234's Avatar
Went to dealier today. He said to engage the tire that needs power you must grab the front break, this will engage the other tire. He also said that you must be giving the maching gas. If you let off the gas the other tire will re-engage. You must be giving it constant gas or accelerating. I will try this this weekend and let you know if it works.
Old Apr 8, 2001 | 11:13 PM
  #19
Sapo's Avatar
Well, I went riding through the serious mud yesterday and it seemed to do better than when I was trying to climb steep embankments. I wonder if it could have had anything to do with the steep grade I was trying to climb? Pumping the front brakes has more effect in the mud I guess.
The only thing that concerns me is what happened in one particularly bad hole. I have stock tires and in Reverse I gunned the engine and it bogged down for a few seconds and finally the tires broke. It was some pretty thick mud but I wasn't having any trouble spinning the tires in Low. I hope I don't have the beginnings of a clutch problem like another member had.
STLyamwar
Jul 25, 2020 04:44 AM
velcro7279
Aug 24, 2015 01:15 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
