82 250r top end rebuild HELP
Old Apr 5, 2014 | 04:04 PM
nachop's Avatar
You may have to cut it off with a torch.
Old Apr 5, 2014 | 05:01 PM
LT80's Avatar
LT80 Expert
Time to use a chisle and hammer to loosen the nut.
Strike a line parrel with the stud. Turn the chisle and and strike toward the right (moving the nut left).
Worse come to worse, you can split the nut.
Old Apr 5, 2014 | 05:22 PM
Or if you get mad enough,use a small metal cutting blade on a dremel,cut the nut off,pull the cylinder off,remove the cut stud and order a new one. Drastic but I've been mad enough to do this before..
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
