04 predator 90 no electric start/runs great
Old 07-08-2014, 09:54 PM
dlunde's Avatar
Default 04 predator 90 no electric start/runs great
I would appreciate some assistance troubleshooting my son's 04 predator 90. The electric start worked earlier this year, now it cranks with no spark. I can start it 2nd or 3rd try on the kick start so I do not believe it is the stator.....not getting a trigger signal to the CDI when cranking on electric start. Any suggestions where to look next?
Old 07-09-2014, 06:09 AM
Pull the plastic stator cover and clean the pick up coil face along with the outside of the flywheel.Better if you can remove the flywheel and clean the stator and inside the flywheel with electrical contact cleaner. The kick starter can generate more inertia on starting than the electric starter can.Even belt dust build up in the idle gear assembly that works off the starter can slow down electric starting.A good cleaning with an air gun may help. Items #16-20. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus don't overlook a weak battery. If in doubt have it load tested.
chammerbeck
07-17-2015 08:06 AM
1966F100
07-14-2015 12:19 PM
1966F100
07-12-2015 03:08 AM
Unzzy66
07-11-2015 10:01 PM
steveo612
07-11-2015 08:35 AM
Quick Reply: 04 predator 90 no electric start/runs great
