What Honda ATC do I have? Please help
I recently purchased a supposedly running Honda ATC from Craigslist. I was told it is a 200x. It has a kick start AND a pull start. The pull start is currently broke, and being new to the sport, I don't know how to start this ATC?? Or if I need to replace the pull start first, etc. It would really help me in my search for information to know which Honda ATC I have. I have included pics, hope they are helpful ones. Any insight into what I have would be greatly appreciated. Thank you and God https://www.flickr.com//photos/12646...92212861/show/
There is no kick start on the pictures you show....the is only a pull start, which is missing, so you need to replace.
This is a 200X frame with a 200S motor replacement.
If this had the original 200X motor, the kick start would be on the right side of the crank case.
I think what you are referring to as being a kick start, is actually the gear shifter. When (if) you get this started, you will use your left foot to move that lever to select the gear. I believe it has 5 speeds: 1 down and four up
If you do NOT have that part, then you will need to find a starter assembly specific for your motor. You may want to run the serial numbers to confirm what motor you have in there and then start your search. ATC parts are not easy to find but shouldn't be impossible if you look hard enough.
