SuperATV's Rear Disc Conversion
Old Dec 22, 2019 | 09:35 AM
  #21
Albertahonda's Avatar
Originally Posted by 01ssreda4
I uninstalled it a while back. Since i sold my stock brake drum backing plate i left their plate/bearing on the bike. The bearing has to be replaced about every 2nd or 3rd mud ride because its not sealed well. Not super thrilled how it turned out, your results may vary.
So your saying the super atv bearing always fails? When you had that setup what did you do with the reverse cable?
Old May 11, 2020 | 04:12 PM
  #22
Turtle WV Bennett's Avatar
It works off your factory cable. However, it is a hydraulic caliper. If you were so inclined to find a left hand master, and run the line, bleed the system, well then you'd have a hydraulic setup.
Only problem with that is that most Hondas have a setup to engage reverse off of a an extra cable on that left brake lever.
Be interesting to find a different way to engage reverse so you can still run hydraulic rear disc.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
