91 trx250x backfires and runs really ruff
Old Aug 2, 2014 | 05:13 PM
zz8t's Avatar
Default 91 trx250x backfires and runs really ruff
hey guys,
I have a 91 trx250x and about three months ago it just died on me, I was able to pop start it and ride it but I had to keep the RPMs really high. Today I finally got around to cleaning the carb out and put a new spark plug in there but it didn't help. I tried kicking it for a while with no luck so I was towing it behind another quad and it finally started. When I had it running I had to keep the throttle wide open to keep it alive, but it just sounded terrible it was coughing and backfiring the whole time.
I am going to tear down the motor tonight and see whats wrong with it. Is there anything I should pay special attention to? Is there any way the timing could have gotten off track mid ride?
Old Aug 3, 2014 | 02:29 AM
Although it could be a problem with the engine, it could be electrical or even fuel again, dirt or water can block a newly cleaned carb. Check valve clearances and do a compression test before tearing into the motor. The later, lengthways crank 250 has a dodgy timing chain adjuster but I think your engine will be similar to the 300 which was fairly bullet proof.
Frisky2050
Apr 9, 2020 11:19 AM
skittero
35
Mar 1, 2019 12:39 AM
Ringwood
Jun 27, 2015 03:02 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
