2001 Honda Trx400ex starting problem
Old Apr 22, 2017 | 10:50 AM
Chrisbturbo's Avatar
Default 2001 Honda Trx400ex starting problem
Ok maybe someone can help me out
2001 Honda trx400ex quad
battery has almost 14 volts when check with meter
new solenoid when you jump it the starter turns and try's to crank
no nuetral light when in nuetral
new battery cables
when my buddy used to push start it it would run you could hit the electric start and you could here it but the lights would flicker and every time you hit the gas they would dim and the nuetral light would do the same
now there is nothing when you try hitting the electric start
fuses have been checked and replaced
any other things I'm missing?!?
Old Apr 23, 2017 | 02:38 AM
"new battery cables"
Well the battery isn't connected to the rest of the bike's electrics, so either the battery earths are bad, or the wire(s) from battery positive to ignition switch are not connected. As the alternator feeds the ignition when the bike is running (that's why the green light comes on) the fault is between battery and the regulator (pos or neg).
Old Apr 23, 2017 | 12:31 PM
Fixed it yesterday where the neutral light connects down by your foot was so dirty and greasy that it wasn't sending the signal that it was in nuetral cleaned it out it pack on and fired right up
It was a fun night of tracing wires though lol
