Hey, I have a 2008 Honda trx 420 shift problems
Old 05-10-2018, 09:21 AM
Brayden Young's Avatar
Default Hey, I have a 2008 Honda trx 420 shift problems
I Went mudding then code 24 came up and so I decided to air compress my wire going to my shift motor water cane out worked for 20 min then stopped so I took shift motor apart cleaned it water cane out of there to so I cleaned it right up put it back together and still code 24 was there ... thanks in advance
Old 05-19-2018, 08:11 AM
Sorry not to answer sooner but kept forgetting to look up code 24 in the workshop manual at work. Anyway it is shift motor fault, or wires to it. I would check everything is clean and dry again, some insulation may have shorted across when wet and now be tracking. I have known it to be false readings though, as the fault code system seems to rely on ecu sending voltage to motor, and angle sensor detecting movement. If it doesn't, it fault codes, but some angle sensor faults mean they don't send a signal back to motor.
robaviles
06-17-2018 02:16 AM
rgjackson
09-17-2015 11:21 AM
Awesomeness
09-13-2012 09:09 AM
hondaaaa350
11-30-2008 07:47 AM
Quick Reply: Hey, I have a 2008 Honda trx 420 shift problems
