actual tire size for trx450!
The OEM tires on the fourtrax 450 is slightly less than 24 inches tall. EVEN if you air your tires to the maximum reccomended, they are only a little over 24 inches( no more than 24 and a half inches). So, if you buy an aftermarket 25 inch tire, you will be gaining about an inch of ground clearence.
