Rubicon Hydro in Cold Weather
Old Sep 20, 1999 | 11:00 PM
P.J.'s Avatar
Anybody have a guess as to how the Rubicon's Hydro Trans will work in cold weather. I hang out in Minnesota and Wisconsin....hand warmers are the first thing I usually add to a new ATV.......and I know the hydrolics on my tactor do not like to work when I wake them up when it is cold out! I'm not talking California-sweater-cold, I talking long-underwear+snowmobile-suit-or-freeze-your-nads-cold.
Old Sep 21, 1999 | 08:49 AM
01ds650's Avatar
I never thought about that. I understand the tranny is like a hydrostatic drive. If you've ever driven a combine or even a bigger mower you might be able to relate. Maybe it will need a little warm up time??? I'm sure Honda has done their homework on this tranny, but then again Hondas are kinda cold blooded.
c-ya,
Andrew Thomas
'99 Scrambler 400 & '99 Trailblazer, both with RCR mods.
Old Sep 21, 1999 | 10:19 AM
Tree Farmer's Avatar
PJ, how do automobiles with automatic transmissions perform during wintertime in your area? If severe cold weather deadlines automobiles where you live, a Honda ATV with some fluid coupling in its automatic transmission might have problems under the same climatic conditions.
Tree Farmer
P.S. Do you currently ride a Polaris, by chance?
T.F.
Old Sep 21, 1999 | 09:11 PM
P.J.'s Avatar
T.F.,
Yep, I currently ride a Polaris...but not much longer. Lack of reliability is pointing me in other directions.
Old Sep 23, 1999 | 01:47 AM
petesbween's Avatar
The Hondamatic is a sealed unit, like Honda's hydrostatic drives on their mowers. It runs with fairly high hydraulic pressure. When you put alot of pressure on a fluid, it gets up to operating temperature in seconds. I would think the tranny oil will also help the engine oil heat up more quickly, since the trans and engine use the same oil supply.
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
