2012 420 Rancher fuel problems
Old Oct 6, 2019 | 10:12 AM
vero125's Avatar
Default 2012 420 Rancher fuel problems
Replaced sparkplug, fuel filter, ran about one hour. Cut off, cranks but will not start. Plug is dry. Fires with starting fluid. Can hear fuelpump cycle when key is turned on. Pulled fuel line off pump gas going to pump. Pulled exit line off at pump, no fuel with key on. Bad pump? Suggestions. Thanks John
Old Oct 7, 2019 | 02:27 AM
Are you sure you can hear the fuel pump, and not the servo motor (ICAV) on the throttle body? I would guess at a failed pump. Take the high pressure line off the fuel pump unit and see if it gushes fuel when you switch on. If it doesn't, check you are getting power to the pump and, if you are, fit a new pump. You can get pumps without the housing etc, now, from aftermarket suppliers, but they are fairly difficult to fit.
Old Oct 7, 2019 | 05:29 AM
vero125's Avatar
I will check the voltage. I took off the high pressure line, nothing. I was checking those replacement pumps/motors. just want to get the right one. Thanks John
Old Oct 8, 2019 | 02:06 AM
One thing I forgot to mention is the fuel pump fuse, worth checking if it is OK,. Also just noticed you had been changing the filter, is it possible you loosened one of the connections to the pump, either the plug on top of filter/pump unit, or the ones inside, from there to pump?
Old Oct 8, 2019 | 05:07 AM
vero125's Avatar
I pulled the pump apart and put 12 volts directly to it. Nothing, ordered a new pump motor.
Judd
Jan 10, 2011 05:21 PM
buzzshep62
Oct 3, 2010 10:05 AM
skidoofan
Sep 30, 2010 08:49 PM
jsully
May 12, 2009 05:08 PM
trout
KTM
Aug 26, 2002 06:55 PM
