Finally fixed that god-awful squeek!
Old Jun 24, 2001 | 05:46 PM
250rampage's Avatar
Every time I would ride my 400ex hard and for an extended period of time, the front end would squeek like an old materess at Motel Six. And, as usual, after a trip to Broken Spokes (a local MX track), the front end started to squeek again. Being fed up with aerosol lubricants that only work for a day or two, I took both front shocks off, cleaned them with engine degreaser, and put liberal amounts of industrial black-streak grease on, and put it back together. Not only is the squeek gone, but the front suspension feels like it moves much smoother! (This second one might be an illusion of my insanity, i'm not sure). So, for a half hour of work, my front suspension feels wonderful again!
Old Jun 24, 2001 | 06:41 PM
bermbanger's Avatar
My 300 does the same. Exactly where did you put the grease on the shocks at? On the shaft or where it connects to the frame.
Old Jun 24, 2001 | 06:54 PM
250rampage's Avatar
Ooops, I can't believe I left that out. Where it connects to the frame, there is a bushing in each mounting bracket, which I pulled out, and greased.
Old Jun 24, 2001 | 10:24 PM
redrancher350's Avatar
my rancher does that if you hit large bumps, turned out to be the spring rubing the shock. i need to do that tomorow.
Jmuddin284
Jan 19, 2026 07:16 AM
greg74
Sep 10, 2019 03:03 PM
austinwhitton
Aug 11, 2015 06:21 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Derek Allen
Jul 22, 2015 09:25 PM
