recon troubles
Old Jul 4, 2001 | 05:06 PM
mick49157's Avatar
I have a 2001 recon that is having a problem. after a while of riding it will suddenly just stall out. when i re-start it, it will idle fine but once i hit the throttle even the slightest it will die again. It doesn't do it very often but when it does if i let it sit it will normally go away. No it's not out of gas it had a full tank. Could this be a result of overheating, is vapor lock the problem if so does higher oct. gas fix it? Could there be a trouble with the choke? has this happened to anyone else?
thanks
Old Jul 4, 2001 | 05:55 PM
RedReconRider's Avatar
That happens to me every now and then. It happens when the bike lands kinda hard. I hate it when it happens but I have no idea what it is. It goes away by itself too. I have no idea[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 4, 2001 | 07:27 PM
LotusPosition's Avatar
I had this same problem when I first got mine. To make a long story short, I removed the float bowl from the carb, and found a number of small black chunks of something unknown. I took carb cleaner and thoroughly cleaned both bowl and carb internals. I also checked the tank filter, but found nothing The bike has never shown these symptoms since.
I can't prove that this was the problem, as there also could have been water in the bowl. You could try opening up the float bowl drain screw, and see if that helps. Turn off the fuel valve first. It is the slotted screw, slightly recessed in the left lower part of the carb bowl. Leave it open till the flow stops. If this doen't help, try my other suggestion.
Old Jul 4, 2001 | 07:33 PM
kkkiller300ex's Avatar
maby your gas is off check that also check the wires if they got wet they may have bad connections your ckock could be a problume or your carb is fuc# your flots may not be working right or your jeting may be off that is my best gusse you may be at the wrong altatude for you jeting talk to kkkiller250x on her he may know he had one and had a lot of problumes he fixed good luck.
Old Jul 4, 2001 | 07:45 PM
KKKILLER250X's Avatar
well i see kkkiller300ex who knows nothing about recons has replied , i had a recon and had the same problem with my recon and i figured it was the carb so i put some dry gas in it and filled the carb with cleaner and then blew it out with an air compressor and theen it was fine , and also when it did it before i pulled out the choke lever all the way and started it and drove wide open for a minute and it fixed it . good luck
Old Jul 4, 2001 | 10:04 PM
mick49157's Avatar
thanks guys i'll try this i'm glad it simple to cure
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
