Perch for stock 400ex clutch lever
When I removed my stock e-brake and perch assembly, I just went with a Moose CR250 perch and lever. From what I remember though, most of the standard aftermarket perch and lever kits are a little different than the stock setup, in that the portion where the lever attaches to the perch is a little thinner than a stock clutch lever. So...I don't know if you can find a different perch that will accept the larger stock lever. I suppose the stock lever could be used with a CR250 type perch...all you would have to do is grind/file down the area near the bolt hole until it fits properly.
