Need Help with Honda Foreman 400, won't start.
Old 08-17-2001, 10:56 PM
Need4Speed's Avatar
O.k. here's the deal. My foreman was leaking gas out of the bottom float overflow tube so I took the carb off found a tear in the tube befroe the valve that's in it. Fixed that. Now I sold it today and the guy I sold it to said it leaked gas all over the place and then quit. I checked and there was another tear in the tube so I fixed it and the leak is solved. Now I tried to start it and it won't start. It has spark, fuel, compression, and it doesn't leak any air anywhere. The plug was wet when I took it out and I blew it off with air and I have plenty of spark but it won't start up. What's the deal? I've gotta make it run because it's no good to either one of us if it doesn't run. Thanks a lot!
Old 08-18-2001, 12:08 AM
KILLER250R's Avatar
I know this may sound stupid but did you turn on your gas?
Old 08-18-2001, 01:19 AM
Elrancho's Avatar
possible flooding with evaporation of all the lighter fuel components. Fix: remove spark plug crank the engine for a while to get fresh air in the cylynder. Replace plug ( they fire differently under compression than in open air and may in fact be misfiring. ) Try starting zero choke, if that's a no go try a touch of ether.
greg74
09-10-2019 03:03 PM
bigred20653
08-31-2015 12:41 PM
Kodiak-vic
07-29-2015 03:06 AM
heath legg
07-24-2015 01:01 PM
07-22-2015 05:00 AM
Quick Reply: Need Help with Honda Foreman 400, won't start.
