Amount of teeth on a sprocket for 300ex will do what?
Old Oct 30, 2001 | 11:42 PM
Sportax300EX's Avatar
I have a 2001 300EX and i wan to know what amount of teeth on what sprocket i should use for more power.
what should i use for more speed?
thanx
Old Oct 31, 2001 | 10:01 AM
Sportflr's Avatar
For faster acceleration use either a smaller front or larger back.
For more top end speed use either a larger front or smaller back. Keep in mind these changes will not give you any more horsepower just better gear ratios to suit your style. If you are just experimenting the cheapest way would be to buy 2 front sprokets one tooth smaller and another one tooth larger than what you have now and give them a try.
Old Nov 1, 2001 | 03:03 AM
KNOWSALOT's Avatar
The Facility
The 300EX does great by going up 1 tooth on the front only. Whether you are using it for trails or motocross. We wonder why Honda didn't do it from the factory. You will not notice a power lose on the bottom with this sprocket but it will give you more top end.{still don't go looking for 400's though]. If you have taller than stock rear tires, I would not recommend you up on the sprocket at all. Just keep it the same.
Customer Service #1
May 15, 2020 08:46 AM
buddieboy
Dec 9, 2016 05:50 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
