400ex gearing and 22" tires opinions
Why does everyone say a stock 400EX does 65-68? did you check your throttle?? my 00' 400 will top out at 80mph on flat asphalt and its all stock!!, no mods what so ever. are you just hiding its true potential to those banshee lovers???
#17
You can get off the stock chain without cutting it, all you have to do is remove the swing arm. You can change the sprockets without taking off the chain, as long as you have enough adjustment to bring it to the proper amount of slack. If you are realy changing the gearing, you will have to add or remove links.
[This message has been edited by TRX400EXitement (edited 01-07-2000).]
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
