Charging Battery on ATC 250ES
Old Jan 16, 2002 | 03:25 PM
Morgan's Avatar
Does anyone have any instuctions for charging the battery on a ATC250ES? Is it best to remove the postivie cable to charge the battery while it is in the bike or is it good enough to just turn the ignition switch off?
Thank you.
Old Jan 16, 2002 | 09:45 PM
KNOWSALOT's Avatar
The Facility
You can charge your battery as it is without removing or disconnecting anything, but do leave the ignition switch off.
Charge your battery with a charger that has a "trickle charge" or a 2 amp setting only. Charge it for at least two hours and then charge till it shows fully charged.
KNOWSALOT
MATT BOOTH
Technical and How-To Articles
Sep 22, 2015 08:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
