Question about 250r carbs????
Old Jan 19, 2002 | 02:04 PM
sparkster's Avatar
What exactly will a 38mm carb do to a 86 250r? Is there such a thing as too big or can you always go bigger? It has other mods.
Old Jan 19, 2002 | 03:35 PM
Schoebs's Avatar
Sparkster,
Intake is directly proportional to exhaust... What else have you done to the wheeler??? Do you have a stock pipe and silencer??? Stock porting? Stock intake manifold, reed cage, and reeds??? Air filter????
It really all depends... If you took a totally stock machine and only bumped up the size of the carb by 4mm, I personally think the gains would be limited. You would see something, but not what I think you are expecting.
Hope this helps.
Old Jan 19, 2002 | 06:57 PM
HondaMan85's Avatar
What i have generally hears about carbs is that the bigger the size of it, the better it is for top end power; the smaller the size, the better it is for low end power.
Old Jan 19, 2002 | 08:59 PM
sparkster's Avatar
It has fmf pipe and muffler, is ported and polished, and has a K&N air filter. Not sure how much it is ported.
Old Jan 20, 2002 | 10:28 AM
POOLGUY's Avatar
If you already have port work and air(k/n)the carb will make a difference you need a good pipe too and your choice of pipe will depend on where you want your power to be (LOW-MID-HIGH) JUST A WARNING IF you haven't had much experience with jetting a carb sometime ot can be a real pain. good aftermarket reed cage will make a big dirrence too.. hope this helps
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
