anyone run high octane fuel in their 400ex???????
Old 04-21-2002, 12:01 AM
PismoGuy400's Avatar
i was wondering....what are the pluses and minuses to runing higher octane fuel (110+) my dealer told me not to go higher then 110 . but if anyone is tell me what the difference from 87 or 92 octane. and if i do chose to run around 110 would i have to do anything to the jetting or anything like that?...thanks
pismoguy
Old 04-21-2002, 12:11 AM
tprender's Avatar
If you still have a stock motor you will be wasting your money. Do run 92 or 93 in the stock motor. If you ever do run race gas, you will find that you might even have to rejet from different brands.
Old 04-21-2002, 11:04 AM
Rockey's Avatar
When you are talking about JUST the octane rating it is simply a numerical rating in relationship to its resistance to detonation. The biggest myth about octane is that it will burn slower or faster depending on the rating. This is simply not true (http://www.cs.uu.nl/wais/html/na-dir...line-faq/.html). Another myth is that a higher octane will give you better gas mileage. This might be true to a very small degree with cars because some models have a knock sensor. This allows the car to retard the timing when detonation occcurs. I don't know of an atv with a knock sensor. Higher octane will resist detonation with higher compression engines. Some race fuels have additives that cause the fuel to burn faster or slower, but it definitely is not the octane rating that is responible.
Old 04-22-2002, 12:02 AM
so i shuld just stick w/ the regular 92 like i have been using???
Old 04-22-2002, 04:24 PM
LogLeaper's Avatar
Well said Rockey.......couldn't have wrote it any better
91' KX80
00' Trailblazer
01' Rancher ES
02' Interstate enclosed trailer to haul'em
Old 04-22-2002, 05:27 PM
Mitteer's Avatar
I run a 50/50 mix between cam2 and regular high octane pump gas. The advantage I have seen is mostly how clean it burns. Also easier starting. You have to look at spark plugs differently due to the lack of residue on them. Where you see the heat change on the electrode determines if you are running lean or rich.
Old 04-22-2002, 11:59 PM
.....so should i just stick w/ the regular 92 like i have been using???
Old 04-23-2002, 02:25 AM
icav's Avatar
oops wrong thread[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old 04-23-2002, 09:26 AM
Mitteer's Avatar
I like it but it is expensive. you might see a mild performance gain but not much. You have to weigh the cost with how your plugs look or how hard your machine starts. Also your machine will run hotter with these high octane fuels.
Old 04-24-2002, 12:15 AM
ouch..that one hurt....i hate having to stop for 15 minutes in the middle of a long cruze through the dunes because it is running hot ....i thing the higher octane is more trouble tha its worth...ill probably just stick w/ 92
thanks for all the help guys
pismoguy
Quick Reply: anyone run high octane fuel in their 400ex???????
