release date for the Rincon?
Old May 1, 2002 | 01:22 AM
1BEARMAN's Avatar
Muddy4life
Can you tell us if the Rincon will have a low and high range?
Bearman
Old May 1, 2002 | 09:32 AM
MUDDY4LIFE's Avatar
I'll check the stat sheet at work!
Bill
Old May 2, 2002 | 12:20 AM
goattrotter's Avatar
Hey Muddy4life:
Are sure it will have a low range? I thought they were saying it would only have drive!
Old May 2, 2002 | 05:32 AM
MUDDY4LIFE's Avatar
I am sure I read on my spec sheet that the Rincon will also have the option to go into the ES mode to?I will double check my spec sheet at work today and post back with you guys later tonight.I'll also double check on the low range to?
Bill
Old May 2, 2002 | 10:48 PM
  #15
MUDDY4LIFE's Avatar
Ok,
here's what my spec sheet reads,
The automotive style Honda transmission features a hydraulic torque converter,three hydro clutches and an electronic control unit[ECU]to automatically select one of three forward gears and one reverse gear.The ECU monitors throttle opening,vehicle speed,engine RPM,gear selector position,brake application and engine oil temperature.The Honda trans shifts electronically----eliminating unsightly and trouble prone vacuum lines and features engine braking,unlike conventional belt drive designs.
The ESP allows the rider to manually select gears by simply pressing two push buttons mounted on the left handlebar.
Trax loc enables the rider to shift between 2wd and 4wd with a simple thumb operated switch.
A convenient colume style shift lever permits the rider to easily select Drive,Neutral,or Reverse.[I see nothing about a LOW range]
Hope this helps you guys out?
Bill
Old May 3, 2002 | 01:59 AM
  #16
1BEARMAN's Avatar
Thank you for the info, I was told it did not have a low range, guess that it wont.
Bearman
Old May 3, 2002 | 11:45 PM
  #17
lovinhonda's Avatar
On Honda's web site, they say it has 3 forward gears and one reverse. I take it that two of them is for drive than nuetral than reverse. I also heard from somewhere that it has a low gear on it but the computer computer shifts it in automatically for you. But thats what I heard about the low gear.
Old May 4, 2002 | 03:28 AM
  #18
MUDDY4LIFE's Avatar
3TV,
the shifting of the gears on your own on the Rincon is nothing more than the Electric Shift Program [ESP] that is available on Honda's other Utility ATVs.
Honda is STILL missing the boat with this model,I mean,old fashion drum style brakes in the front,and it does NOT have the option to LOCK the front Diff.Its using a smaller 37mm carb opposed to the 42mm thats used on the new 660 Grizz.Im just not sold on this new Rincon yet,especially at 7599?
Bill
Sep 30, 2015 01:37 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
awer1968
Sep 8, 2015 11:02 AM
chewy78
Sep 8, 2015 10:37 AM
