My 250R is slower. Something is wrong.
Cool. Thanks for tip, 2fun. Right now I'm in the 3rd clip position and is was in the second clip. So I'll drop down to the bottom position and see what happens. Also, I assuming my pilot is stock (48) even though I've never seen it simply because most people never bother to open the carb to change it. If I am, do think looking at my mods (see first my first post), what pilot would you have put in it?? This could have me close. I think I finish my leaning my mixture w/Klotz synthetic technoplate from 32:1 to 40:1.
What do you think?
What do you think?
Try only one notch at a time (I know I said go to the 5th, but that was before I knew you had it backward).
Only change one variable at a time, or you will not know WHERE you are at!
The needle will affect ~ 1/4 - 3/4 throttle, so this MAY take care of the problem, but the slow circuit is mainly controlled by the air screw, and pilot jet.
You can try changing to a larger pilot and see if it helps too, but like I said, only change one thing at a time.
A larger pilot jet will also give you more fuel thoughout, as it is adding fuel to the other circuits right from the beginning.
Does your lid have holes in it?
Have you tried turning in, or out, the air screw? Did this help, or not?
Going from a 32:1 to 40:1 will also richen the FUEL to AIR RATIO.
You should be fine with 40:1
Once you mix it at that, leave it there, or it will also be adding another factor to your jetting problems.
Do you have a manual??
#15
#16
<< no, no holes in the box. Yeah, I've played around with the air screw but I just leave at 1 and 1/2 turns out. I wouldn't know how to tweak it correctly anyway. screw in or out and why? what leans and what richens in terms of the air screw? >>
Turning IN the airscrew RICHENS the mixture.
Turning OUT the airscrew LEANS the mixture.
If it gets better turning it IN, you are running lean, and vise versa.
#18
Plug check process:
I run a new plug in a warm engine and rev out full throttle in about 3rd for 5 seconds and pull the clutch and kill the engine and I check the plug to see how the main jet is.
for the needle, I do the same but at about 1/2 to 3/4 throttle.
Yes I have a manual. But you know, "lightly seating a screw" is not an exact science. One guy's idea of "lightly seat" vs. another guy's can be off by 2 MM.
I don't have the tools to check float heights and I'd be nervous about doing it because you can screw up your float level and have a leaking carb that won't stop dribbling gas. I've seen it happen to mechanics. Carb floats and float valves are funny, touchy animals if you don't do it perfectly.
#19
Sounds god on the plug check!
Floats aren't that bad. I've had to adjust a few. Just gotta read real carefully, so's you do it right.[img]i/expressions/face-icon-small-wink.gif[/img]
P.S.,
You can use a machinists steel rule (under 10 bucks), and read the side that measures in thousandths.
You don't have to adjust anything if the float height is already set correctly.[img]i/expressions/face-icon-small-wink.gif[/img]
P.S.,
#20
