speed up my 300ex
Old Mar 8, 2000 | 09:20 AM
RangerSX's Avatar
How can i get ahold of Magic racing???
Old Mar 8, 2000 | 10:51 AM
DanHonda300ex's Avatar
Rangersx,I got a 14 tooth sprocket from Rocky Mountain Atv.It cost me 8.00.
Dan
'98 Honda300ex
Old Mar 8, 2000 | 02:44 PM
SNELL's Avatar
Ranger SX I have a couple of phone #'s for you Majic Racing 1-800-999-4594 MON-FRI 10-7pm est SAT 10-4pm est and Rocky Mountian ATV 1-800-336-5437 MON-FRI 9-6 SAT 9-12. Rocky Mountian has catalog Majic dosen't.
Old Mar 8, 2000 | 09:18 PM
y2kTHUMPIN300ex's Avatar
Here you go Ranger- DENNIS KIRK 1-800-328-9280 Renthal front sprocket part no.80-44-14 for the 14 tooth. 24.99 a little higher then some but Renthal makes good stuff. I have a SUNSTAR brand and have had good luck with them I picked it up at a local shop. GOOD LUCK p.s. hows that for service??
Old Mar 8, 2000 | 11:21 PM
  #15
scotster750's Avatar
As a quick note i would like to say that if you put pn the 14tooth front sprocket you will have to remove the engine case saver,and put i washer on each bolt between the guard and engine(300 ex models with reverse lever).The washers will align the reverse lever holdown bracket when the case saver is removed.*** keep chain adjusted properly,and lubed and if their is any question about the chain's life,replace it when removing the case saver.You don't want the chain to break and trash a engine case.
Old Mar 13, 2000 | 03:44 PM
  #16
projectX's Avatar
If you really want power go for the 350x conversion. I did it to my 250x and it is great
it didnt take much time and depending on how much you are willing to spend you can buy a new 350x motor for $1300. For a new motor thats not bad.
Old Mar 13, 2000 | 10:34 PM
  #17
PowerHungry's Avatar
I've posted two 300ex owner reviews on my site. Check 'em out if you are interested...
Planet ATV
Old Mar 14, 2000 | 01:12 AM
  #18
Mike300EX-99's Avatar
What's up ProjectX, nice to see you finally got on board. Lots of info here. Can't wait to go riding again and roost HAPPY, I'll take it easy on him, hehehe!!!
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
