Rubicon gear position problem
Old Jul 8, 2002 | 10:09 PM
muzzy3's Avatar
My Rubicon has about 1400 miles. So far it's been a good machine. Not to long ago however,when shifting from neutral to drive[d1 or d2] the diplay wouldn't show it's normal D. The transmission is in gear because it will still drive, but the variable transmission does not vary.Rpms go up,but it stays stuck in low range unless I wiggle shifter until D is displayed. This is now happening often and becoming annoying.Anyone had this type of problem? If so ANY and ALL help will be appreciated. I think it may be the gear position switch but not certain.
Old Jul 8, 2002 | 10:31 PM
TEXMud's Avatar
More than likely its the linkage on the shifter lever. There are some nuts on there that allow adjusting.
Old Jul 9, 2002 | 08:38 PM
muzzy3's Avatar
How would it get out of adjustment? Nothing seems loose.How do I know which one to adjust and which way, if it is out of adjustment?
neilbedwell
Nov 10, 2018 11:02 AM
txkevin
Sep 21, 2015 02:02 PM
Madshad
ATC 3-Wheelers
Jun 28, 2015 02:43 PM
wildbill59
Jun 9, 2015 02:28 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
