Which atv's ahve true 4WD?
Old Dec 15, 1999 | 12:41 PM
  #21
Bill.Ciliberti's Avatar
A Quote from Dirt Wheels---The Traxter,even with one wheel off the ground,was able to get torque to the wheel MOST needing traction.Unquote-----I beleive that would not qualify as ''TRUE 4X4''====BILL
Old Dec 15, 1999 | 06:55 PM
  #22
rooster's Avatar
That's what I mean, it's hard to tell if it has true four wheel drive or not cause there seems to be stories that it does and stories that it doesn't. I read that when turning, the Traxter allows the inside wheel to turn slower than the outside, for easier turning. Then when the going gets tough, a hydraulically actuated device locks the front differential so all four will spin. Bill, I believe you, but what shootout did you read that in?
Old Dec 15, 1999 | 09:07 PM
  #23
RedRooster's Avatar
The Grizzly and the new 00' Kodiaks are supposed to be "true" 4x4s.
Old Dec 15, 1999 | 10:10 PM
  #24
Racing_Stud's Avatar
I would say anything with "push button" systems or somthing that has a locking diff. I'm not to bright on 4x4 ststems
Evan Johnson 1999 400EX 1988 LT250R
Old Dec 15, 1999 | 10:49 PM
  #25
BONER's Avatar
Neither the Grizzly nor the Kodiak have "true" 4wd.
Old Dec 16, 1999 | 12:48 AM
  #26
Andy Bassham's Avatar
Once again this debate bases itself entirely on what you consider "true 4wd" to be. If you consider it all four wheels all the time in a locked differential, then there are only two. The responses are always going to be fuzzy here, because different people consider the question in different ways.
Andy Bassham *(1999 Arctic Cat 500 4x4, 1989 Honda 300)*
Old Dec 16, 1999 | 11:46 AM
  #27
Rooster,go to Junes issue of DW,Go to page 40 under the heading REAL WORLD TEST.
Old Dec 16, 1999 | 10:04 PM
  #28
SprintPusher's Avatar
Everyone claims to be a true 4 wheel drive, if you do your home work, you will find the Traxter shows how it should be done. Read some of the reports here in the atving.com world.
shimanok2
Jan 29, 2016 07:37 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
