AXLE NUT ON A FOREMAN 400
Old Mar 24, 2000 | 12:12 AM
josh1's Avatar
I've been trying to get the axle nut off my Foreman 400. My Honda Dealer said to heat it up to melt the lock tight. I tried that but it still wouldn't budge.I've been trying with a ratchet and a impact. The reason for removing it is to get at the brake drum. Help would be much appreciated ASAP. Thanks
95 Honda Foreman 400 4x4 "Traks Max"
Old Mar 24, 2000 | 01:04 AM
MUDMANN's Avatar
don't heat up the metal... it can cause it to weaken and bend, if you don't know what you are doing. Clean the nut area w/ wd-40 - I mean sparkly clean... dirt can be your nemesis. Here are a few options:
1) try wd-40 and spray around the axle nut. Let the wd-40 do its works for about 3-5 minutes. Try it.
2) Act as if you are tightening the bolt. Tighten it and try to loosen it (also, wd-40 can be of help). That sometimes does the trick... I had to remove the axle nut to clean out my rear brakes.
A question: do you have two large adjustable wrenches? or did you use 1? If you use two, the job is MUCH easier. Hope this helps
-E
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
patrick.oc123
Sep 15, 2015 02:45 PM
