DETERMINING SPROCKET SIZE
Old Mar 25, 2000 | 12:32 PM
fasttrax's Avatar
I have a 400ex, wb e-pipe, wb rev kit, and 20" skattrak haulers (7 paddle). I have the power,but i'm spinning and usually dig in and have to turn around. would a larger or smaller sprocket help? front or rear? I'm hitting the base of the hill usually in third and in 1st or 2nd at the top pending on the sand hill. I've tried shifting my weight and paddles are at 3psi. HELP!
Old Mar 27, 2000 | 11:25 AM
fasttrax's Avatar
When does the sprocket size get increased? is it best on front or back?
Old Mar 28, 2000 | 01:41 AM
Stroke9's Avatar
It's cheaper to change the front sprocket.
Use a bigger front sprocket for higher top speed. Use a smaller front sprocket for more pull or acceleration, but less top speed.
Old Mar 28, 2000 | 02:24 AM
DunePilot858's Avatar
Fasttrax you might want to just get a new set of paddles. maybe some 8 or even 10 paddles. if you are spinning your wheels you are making the power to pull a bigger set. I wouldn't change the sprocket until you wear the stock ones out. Remember that you will not keep up with a two stroke going up Oldsmobile or anyother big sand hill. It's just what 4 strokes can't do very fast. Anyway i hope this helps you
buddieboy
Dec 9, 2016 05:50 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
merryman
Sep 19, 2015 03:15 AM
