Cleaning out welds on 400ex stock headpipe
Old Nov 24, 2002 | 09:14 AM
la400ex's Avatar
Default Cleaning out welds on 400ex stock headpipe
I have heard stuff about cleaning out the welds on the stock 400ex headpipe. How do you do it? I bought mine with a slip-on on it. Im gonna get a full system as soon as possible but i wanna see how this works. Thanks, Anthony
Old Nov 24, 2002 | 10:36 AM
tprender's Avatar
Take the headpipe off of the quad ad look inside the 2 opening that go onto the head. About 1/2 inside you will see the welds that we are talking about. They are only on the 400stock pipe. Take a Dremial tool or a drill with a stone wheel and grind out the welds so that they are flush with the side of the pipe. This will make the air flow better inside the pipe. You will find that you will not need an aftermakert headpipe after this. By cutting out the welds this will addabout 1/2 to 3/4 hp. Getting the pipe off is the hardest. cleaning up the welds should only take about 15 min. Most of the aftermarket headpipes are the same size as the stock headpipe. All of the gains are in the slip-on.
Old Nov 24, 2002 | 01:20 PM
RSO660R's Avatar
i will add this if cleaning the welds make sure you wash any metal shavings out of the head pipe before install so you dont suck any shavings into your cylinder.
Old Nov 24, 2002 | 10:14 PM
la400ex's Avatar
Thanks, Im gonna do that as soon as I get the chance. I need to go pick up a stone wheel for my drill. I dont have a dremel. I've been thinkin about gettin one of those. Thanks again, Anthony
Reactant
Mar 30, 2022 02:08 AM
slowgsxr97
Mar 18, 2022 03:40 AM
traumajunkie
Jul 23, 2015 02:10 AM
95wolv
Jul 21, 2015 12:25 PM
Reactant
Jul 16, 2015 10:29 PM
