rear bearing replacement
Old Dec 21, 2002 | 09:37 PM
liftkit's Avatar
Default rear bearing replacement
i have a trx 250x and i am in the process of getting my rear axle out but what has stopped me from doing this is, i cannot get my sprocket hub off. it will not budge at all, wiggle or nothing. Its not welded anywhere. i took a 15lb rubber sledge hammer and hit it a bunch of times and nothing. Need all the info, opinions, suggestions possible.
Old Dec 21, 2002 | 10:16 PM
roscoe69's Avatar
Liftkit
it must be on a spline, i wonder if it comes out that side or the other direction. I had a 200 that we had to replace bearings every year it used to come out other direction. Im probably not much
help
Old Dec 22, 2002 | 12:35 AM
tprender's Avatar
On a Honda the sproket hub does not come off. You take the rotor side off to get the axle out. Sproket hub will only come off by using a press. Undo the nut next to the brake rotor, it is reverse threads, there is a clip on the axle under the nut to get it off. Then the axle will come out
Old Dec 22, 2002 | 04:56 PM
StevieD's Avatar
ya, Tprender is right.
coolguy420
Jul 10, 2015 01:17 AM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mikea1978
Jul 4, 2015 12:37 PM
bikedad3
Jul 2, 2015 02:15 AM
