250ex tires
Old Jan 18, 2003 | 11:15 PM
pensy250ex's Avatar
Default 250ex tires
what tires should I get for my new 250ex.
thanks tom
Old Jan 19, 2003 | 09:16 AM
BK's Avatar
BK
Default 250ex tires
I put 22X10X9 Gators on mine. They were maybe 1/4" shorter than the stock tires. They are much stiffer than the ballon tires that come on it making it feel more stable. They drastically improved traction in all situations. You will be amazed how well the EX will go through mud. My brother's Wolverine with the stock tires couldn't do much better than my 250. Mostly due to low weight combined with high traction.
Have fun with your new machine!
Old Jan 19, 2003 | 11:24 AM
DirtDiggler's Avatar
Default 250ex tires
Tom,
We took the stock tires off of SparkyEX's Cannondale (ITP Holeshots with a bigger rim offset) and put them on his wife's ex after he bought a new set for the Dale. the bigger offset mixed with the flat style sport tires in the rear made it handle better as well as a major jump in stability. I think if you shop around you can find holeshots for $110 for just two tires or around $150 two tires mounted on rims. If you want the bigger offset just ask for Cannondale offset.
Diggler
Old Jan 19, 2003 | 06:40 PM
Mike Chero's Avatar
Default 250ex tires
pensy250ex,
If you are going to get tires for it, might I suggest 4 plys for it. Holeshots, Razrs and Shredders all come in a 4 ply as well as 6 ply. Get the 4 ply, as they are much lighter then their six ply brothers. Weight (more specifically, rolling mass) is your enemy on that little machine. As the only way to keep the gearing stock on the machine is to make sure that you get the same size rears, that pretty much leaves out the Holeshots. The Holeshot XCTs (22") only come in 6 ply. The Razrs come in a 22", 4 ply rears. I'm not sure about the Shredders.
Old Jan 20, 2003 | 01:38 AM
Milkweed's Avatar
Default 250ex tires
Holeshots or Razors!!
Old Jan 20, 2003 | 11:19 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 250ex tires
I run Holeshot XC's on all by sport bikes. They are mounted on ITP rims, that have a greater offset than stock. This makes the bike 3" wider in back and 2" in front. The stock 250 is a bit tippy, and pushes a bit in turns, and this cures both nicely!!!
Old Jan 20, 2003 | 02:04 PM
01redrecon's Avatar
Default 250ex tires
What type of terrain do you ride in?? My brother has some razors on his 400ex and he really likes them. They gave him alot more traction and better wear over the stock ones. If you ride any mud you should consider some gators or realtors. I really like my bearclaws on my recon, they are a good trail tire and are still a little sporty.
Old Feb 12, 2003 | 04:46 PM
sandwarrior02's Avatar
Default 250ex tires
Does anyone know what the wheel bolt pattern is on 03 250ex front and rear?
If so is it the same as a 300ex.
Old Feb 13, 2003 | 11:51 AM
Mike Chero's Avatar
Default 250ex tires
The bolt pattern is 4 (bolts) X 144 (millimeters across). Yes, 300EX wheels should fit.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
