Best upgrades for Rubicon???
Old Apr 4, 2003 | 07:57 AM
  #21
Rubidude's Avatar
Default Best upgrades for Rubicon???
Funkdafied...when starting, it also helps to turn the key on for a minute or two before trying to start it. There is a heater on the carb. that will help it fire a little better. In warmer weather, you shouldn't have any trouble. Might have to use the choke once in a while.
Old Apr 4, 2003 | 11:10 AM
  #22
Rubijoe's Avatar
Does anyone know how long it takes to install the Warn 424 kit on a Rubicon? Are any special tools needed?
Old Apr 4, 2003 | 05:44 PM
  #23
slab's Avatar
i cant say about the 424 kit but the highlifter kit took about 2 hours. it was installed as a package deal that included the locker so it was out for longer than that. you have to take your front diff. loose and slide it as far forward as possible so the stock driveshaft will clear the output shaft from the tranny. its pretty time consuming and the bolts in the front diff are locktited from the factory so there pretty well in there. good luck
Old Apr 4, 2003 | 10:12 PM
  #24
Rubijoe's Avatar
Thanks for the Info, How much did the setup cost all together?
Old Apr 4, 2003 | 10:17 PM
  #25
slab's Avatar
http://www.highlifter.com/store/lockun-lockpckg.html for the rubicon it is 615.00 plus shipping
Old Apr 5, 2003 | 10:52 AM
  #26
Funkdafied's Avatar
Thanks Rubidude!! I didn't know about the carb heater. I do use the choke, because it wouldn't start without it. Well I'm leaving to go pick up my filter and warn disconnect. Thanks again for everything guys. This is trully a good site! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2003 | 07:33 PM
  #27
Rubi's Avatar
The Warn 424 takes about two hours to install by an average mechanic like me. It works great. Best option to add to the Rubicon, I think.
Old Apr 9, 2003 | 09:36 PM
  #28
Rubijoe's Avatar
Thanks for the info, maybe I'll give it a whirl!
shimanok2
Jan 29, 2016 07:37 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
