Master Cylinder Help
Old Apr 10, 2003 | 09:48 AM
db's Avatar
db
Default Master Cylinder Help
Range Rover,
You have been a great help and I really appreciate all your advice. Now, onto the choke cable of which I think I have figured out. I think the guy, from whom I bought my Foreman, must have let it sit in water. Thanks again and the best to you.
Old Jun 22, 2005 | 11:34 PM
midwest's Avatar
I know this is an old post, but I am having the same sort of problem and was hoping for some help. I am working on my neighbors 1986 honda trx 250. No front brakes. I took all the brakes apart, cleaned, adjusted and though that would solve the problem. I have no pressure at the brake handle. I then tried bleeding the brakes to no avail. then I tried suggestions about bleeding the master cylinder as described and no help. I unscrewed the banjo bolt to test the master cylinder and it squirted all over the place on the first pull. so then I put it back together, bled through the banjo bolt, and opened the bleeder valves and let it drain for about 30 minutes. both bleeders are dripping fluid and i had to fill master cylinder about 5 times. but I still don't have any pressure at the brake handle.
PLease Help!!!
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
