250ex rev limiter
Old Jul 5, 2003 | 12:46 AM
duneittilludie's Avatar
Default 250ex rev limiter
blasterdevil2- my wife used to have a 250 ex and the rev limiter would kick in way too soon on hers also.one solution is to go to a taller tire to change the gearing .on my wifes 250 ex we went to a 22" rear tire and it helped quite a bit with the rev limiter problem.
Old Jul 5, 2003 | 03:47 AM
300exG's Avatar
can i just take the wires that go in and splice them with the wires that go out
Old Jul 5, 2003 | 04:05 AM
250R4LIFE's Avatar
NO
Old Jul 5, 2003 | 11:01 AM
95wolv's Avatar
To expand on what 250r said, splicing the wires would just bypass the entire cdi unit, and you would end up with no spark, and a dead motor. The cdi unit is needed to build the energy pulse sent to the coil to fire the plug, it also controls the duration and timing of the energy, in a word, it is the 'brain' of the spark system, bypass it, and you are 'brain dead ' !!!!!
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
