Stripped Oil hole
Old Apr 8, 2003 | 01:26 PM
Honda5's Avatar
Default Stripped Oil hole
I posted below a topic on ft./lbs. to use when tightening the oil drain plug as I didn't want to overtighten and strip out the internal threads as this happened to my neighbor. He's without a computer so I ask for him on the procedure he needs to follow to repair his bike.
Old Apr 8, 2003 | 03:44 PM
03foreman's Avatar
Use a HELICOIL. You drill the hole out tap it and screw this in, its like a sleeve.
Old Apr 8, 2003 | 05:15 PM
Coyotechaser's Avatar
If the coil doesn't work he might have to replace that part of the engine. It is very important when installing the coil to make sure it isn't crooked. If it isn't done correctly he could have a continuous DRIP.
I'm not sure what kind of quad he has but the Recon drain plug tightens at 18 lbf-ft.
Old Apr 8, 2003 | 07:40 PM
tom18801's Avatar
Go to a auto parts store and buy the correct size heli coil then insert the bolt only into the engine and strip it out really good the screw the heli coil onto the bolt and screw the whole unit into the drain plug hole.
Sassinm1
Sep 30, 2015 04:23 AM
tysonbully
Sep 28, 2015 02:30 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
toonces
Sep 5, 2015 01:14 PM
