400ex into a monster for 600$?? possible?
Old Apr 15, 2003 | 03:48 PM
TyreSpinner's Avatar
Default 400ex into a monster for 600$?? possible?
I would probably go with a 416 setup if I was to bore-up.
All I would need to have to do it would be : ???
87mm piston + rings
take my cylinder to a machine shop and have it bored to 416
honda gasket
rejet
Is that it??
Also I'm a complete dumbass when it comes to dismantling engines, would it be a complicated job to dissasemble my motor to bring it to the machine shop. Any thing I should know, I have almost no mechanical experience (yea, i admit it).
Thanks for your help in advance
Old Apr 15, 2003 | 05:17 PM
garyc660R's Avatar
www.nitrousexpress.com
Old Apr 15, 2003 | 05:30 PM
CrAcKhEaD's Avatar
What does removing the choke do? is it worth it? and does removing the welds really work? if i do these 2 will it give me alteast 1hp? thnx~
Old Apr 15, 2003 | 05:37 PM
hutchies's Avatar
Both of these things will work and give you some more power i would also recommend a pipe and rejetting if you are going to do this.
Old Apr 15, 2003 | 05:38 PM
  #15
garyc660R's Avatar
Dude, you only get 2 screaming horses from a complete exhaust.
Old Apr 15, 2003 | 05:49 PM
  #16
Quadfather's Avatar
Most exhaust systems for the 400EX produce 2-5 horsepower. It doesn't sound like a lot, but on a machine that produces 27 horsepower in stock form, that is about a 10% gain. Sounds better when it's put that way, doesn't it.
Old Apr 15, 2003 | 05:57 PM
  #17
garyc660R's Avatar
Remember the pipe shootout? The White Bros pro meg is the best exhaust for the 400ex and it produces 2 more screaming horses at peak power level. Is there a new pipe out that can prove a 5 horse gain?
Old Apr 15, 2003 | 06:12 PM
  #18
nobody answered my last question.
Old Apr 17, 2003 | 12:37 PM
  #19
DSAPP's Avatar
there is no pipe the gives a 5hp gain on a 400EX
Old Apr 17, 2003 | 12:40 PM
  #20
RAPTORAZ's Avatar
There are plenty of pipes that give a 400EX +5 ponies. However those horses are in the midrange and not peak.
