oil burning 400ex
Old Apr 18, 2003 | 12:03 PM
patient's Avatar
Default oil burning 400ex
i have a 99 400ex that burns a lot of oil. it doesn't leak at all. i have to add about half a quart of oil every 15-20 miles. it doesn't apear to smoke that much. want to know if anybody has had this problem with such a great bike. and what would be a fix.
thanks.
patient
Old Apr 18, 2003 | 12:47 PM
thor440's Avatar
My buddies and I bought 4 400ex's. 3 out of the 4 used oil almost since they were new. The other 4 wheeler wasn't ridden very much. They were 99's.
Old Apr 21, 2003 | 12:26 AM
CrAcKhEaD's Avatar
my brother was having that same problem then he put some Lucas additive and it seems to have stopped
Old Apr 21, 2003 | 10:12 PM
yellowexracer's Avatar
Where do you get that Lucas stuff?, i have the ame problem with my quadrunner
Old Apr 21, 2003 | 11:25 PM
CrAcKhEaD's Avatar
At autozone, its called Lucas Oil Stablizer its in a white bottle with red and blue letters. Its really thick and is supposed to make it run 6 degrees cooler
Old Apr 25, 2003 | 12:06 AM
cluby's Avatar
Don't buy any junk addtives you don't need them first how does it run does it still have good power starts easly. How many times if any have you serviced the air filter and did you put something on it don't use motor oil that gets hot and runs off. Use chain lube or something sticky Honda offers foam filter oil that is the best or you can get some from Bel Ray. Has you air filter ever fallin off, you should also update the clamp holding on your air filter I have rebuilt many of 400's because of the air filter fallind off one from a 2002 or new is what your after and use a high quilty oil and change the oil filter don't put it in backwards either don't for get there are two drain plugs and don't forget the washers and replace them after two oil changes.
Old Apr 25, 2003 | 12:33 AM
patient's Avatar
it runns good, has lots of power, didn't change anything, still factory stock, but not sure if air filter has ever fallen off because not first owner.
Old Apr 25, 2003 | 12:47 AM
dzzy's Avatar
Some oil consumption may be normal but half quart\15 miles is too much. It should be smoking pretty good at that rate! Is it possible ur overfilling it a half a quart and it's ending up in your airbox? You know they have a special checking procedure. Then again it probably needs a rebuild. Sorry patient, I don't think any additive can rebuild your engine for you.
Old Apr 25, 2003 | 01:01 AM
CrAcKhEaD's Avatar
well im not saying the additive rebuilt my motor, but it did stop the oil consuption
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
