Would i lose HP with itp 589m/s tires? Plz respond!!
Old Apr 30, 2003 | 09:26 PM
HondaMan1424's Avatar
Default Would i lose HP with itp 589m/s tires? Plz respond!!
I need some information about if i would lose hp with 589 tires on my honda rancher es.
Old Apr 30, 2003 | 09:40 PM
KILLER250R's Avatar
A more aggressive tread pattern will be harder to turn (assuming you are running stock tires) plus a larger size will be much harder to turn. After adding larger more aggressive tires it's always a good idea to compensate by freeing up the airflow going in and out of your motor to give you more power to turn your new 589's
Old Apr 30, 2003 | 09:42 PM
thanks for the information. Ill check into what you said.
Old Apr 30, 2003 | 10:00 PM
does anyone else have any tips??
Old Apr 30, 2003 | 10:11 PM
upnort's Avatar
No you will not lose hp but you will lose performance. You will have more rotating mass, it will likely cut into your top end and accelerationa little because you will have to start more momentem. Improved will be your traction though, a worth trade off in my opinion. I have 589 M/S now on rear and like them but looking to go to mudlites all around.
Old Apr 30, 2003 | 10:13 PM
thanks for the tip and ill see if the mud lites will work.
Old Apr 30, 2003 | 10:19 PM
can anyone else what they think or give me tips about it??
Old Apr 30, 2003 | 10:36 PM
biggin's Avatar
No tips here, but the Rancher is the ultimate sleeper 4X4. They tackle the deep holes with the big boys. I was watching some folks mudding this past week end, and the little 329 went thru the same crap as the 500+ machines.
Old Apr 30, 2003 | 10:38 PM
I know its one bad *** 4wheeler.
Old Apr 30, 2003 | 10:46 PM
anybody else have any tips or opinions on my question or tell me what i should do??
