2000 400ex noise at speed
Old May 6, 2003 | 05:27 PM
QuadTeun's Avatar
Default 2000 400ex noise at speed
Well, I just bought a 400ex about a week ago.
It has a new piston and a couple of new bearings in the engine.
The machine runs absolutely great (I have been a little easy for the bike because the new piston has to be broken-in).
Now I'm gradually giving it some more throttle.
But when I go down the road at speed and high-rpm I hear a rattle noise in the engine. (I had a Blaster before so not really used to 4stroke, maybe this is normal?)
When stand-still it sounds normal, doesn't even rattle when I rev the engine. It's only at high speeds and high rpms.
At first I thought it might be the chain rollers, but when I pull the clutch the rattling is gone, so it has to be in the engine.
Any clues?
Some extra info:
The bike hadn't been run for a while when I bought it
I use 98 octane fuel
Old May 6, 2003 | 11:08 PM
hannahj's Avatar
i culd be the vavles mine are loose and are making rattling noises you should adjust them everyonce in awhile
Old May 7, 2003 | 04:49 AM
QuadTeun's Avatar
Could be, but wouldn't I hear them rattle at stand-still too?
I will check the clearance though, although I doubt it's off because the guy I bought it from has a quad-store and he had the engine apart so I think he would've checked the valves.
Old May 7, 2003 | 01:13 PM
1986atc250r's Avatar
Check any skidplates you may have - they are notorious for making bad noises that sound like something in the engine.
Old May 7, 2003 | 01:31 PM
thor440's Avatar
My headpipe comes loose every now and then, might check that too.
Old May 7, 2003 | 01:49 PM
QuadTeun's Avatar
Well, I checked about everything, but found nothin'. I rode it again for about 2hours, and I think it's just the normal valve-noise all 4strokes have. Think I noticed because I was used to riding a Blaster without any valves. [img]i/expressions/face-icon-small-happy.gif[/img]
Anyways, thanks for the replies.
Reactant
Mar 30, 2022 02:08 AM
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
neo27ny
May 14, 2018 12:19 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
