Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Mini 14 VS Scope
Old Jan 5, 2004 | 01:28 PM
polarisman3's Avatar
Default Mini 14 VS Scope
well this is the second scope that has failed on my mini its always the crosshairs that break....the first scope was a simmons whitetail scope and this last one was a 200 dollar simmons aetec 2.8-10x44 scope...good thing there is a life time warrenty.....so its free this time...anyone else have trouble with their scopes on a mini.....if not what scope are you using.....this last scope lasted 500 rds and the scope before it lasted 1000 rds..
Old Jan 14, 2004 | 04:34 PM
AlaskaBoy's Avatar
It is not what you are shooting or what scope you have on it, it is how rough you are with it, sounds like you throw it around alot. AlaskaBoy.
Old Jan 16, 2004 | 11:30 PM
WILDCARDSHOOTER's Avatar
[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img] polarisman3--this cant be caused by the gun . it sounds to me like external forces at work . i shoot about 500 to 700 rounds a month for the last 5 years in my gun with a tasco tr 4x16x40 and have not made a click of adjustment . i have two other 223cal with 2.5x10x44 aetec and they are my atv rideing coydog chaseing guns and they take a beating with no problems .
Old Jan 20, 2004 | 08:50 PM
This gun gets brought from inside to outside then shot a few times then brought back in. never been nicked or bumped. Not a scratch on this new gun....the dealer said it is very very common for these mini 14's to break or damage scopes.. because of the harsh chamber action. this is not from rough use though.
Old Jan 20, 2004 | 10:05 PM
[img]i/expressions/face-icon-small-shocked.gif[/img] polarisman3 check your mounts either the mounts may be loosening up or putting the scope in a bind . my minnie 30 has a far more harsh recoil than the 14 and i have only had 1 problem with it . a bad set of ring caps that was putting the scope in a bind and it acually shattered the rear lense after less than 100 rounds on the first scope and cracked lens on the second thats when i new there was a problem . as far as the recoil i use aetec scopes alot on calabers like 375 h&h mag 416 rigby 30-378 weatherby these are serious shoulder cannons with recoil that kills most scopes . i would recamend a trip to your local gun smith for him to examin the mounts or install a composite recoil bushing to absorbe some recoil . this is not a common 14 problem . there are 7 guys on our lacal rife match team shooting 14 s in comp with fragile target scopes with no problems .. if ALL FAILS CONTACT RUGER FOR HELP.. when i said external forces i did not mean to imply you were abusing the gun .
Old Jan 21, 2004 | 09:35 PM
maybe rapid fire has somthing to do with it.....there is so much bolt slap that.....well i got new rings today so we will see how that goes...they are SS. well good replies guys....
Old Feb 12, 2004 | 10:54 PM
SPD522's Avatar
Even a cheap scope will hold up to no more recoil than a 223 puts out, Mini or not. You either need to check the mounts and verify it is on true and not twisting or crushing the tube. I have a cheap Simmons on a AR15 flattop and it hasn't had a lick of problems. Had it on a HK91 before that. Lots of rounds fired through it and it has not been babied. It is possible you just got 2 bad scopes in a row but I would still look at the mounts.
Old Feb 13, 2004 | 02:19 AM
Slinger's Avatar
.44 Ruger with the same cross-hair breaking problems. It currently has an el-cheapo Pronghorn that has lasted awhile. ?
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
