Summit Viper Treestand....Any Input?
I assume that you are talking about the new for this season models. I did have a Summit and liked it. It was easy to set up and comfortable once you got to your height. I ended up trading a buddy for an API that he had. Size and weight were about the same and just as comfortable.
Here are the reasons that I got rid of the Summit. 1. The cables were VERY stiff and I ALWAYS made noise when I was putting it on the tree. 2. Since the cables have only a few "knots" it sometimes made it difficult to fine tune placement on the tree. 3. Everytime that I would get the cable into place in the frame of the stand, I would have to pull it into so the "knot" would be in the correct position. MORE NOISE!
I know that my stand was an older one and didn't have the new system so it could be better than what I had. So I also don't know about the extra time that it takes to go from backpack to tree. As for price, just shop around and do the best you can. Even if someone gave it to you, someone else out there would say they would have been able to get a better deal.
As a side note on the API, a buddy was hunting about two years ago and the wind really started picking up. He was getting ready to get down and a 6" to 8" tree limb snapped out of a tree next to him. The limb came down and went between him and the tree hitting his safety harness, pinning him in the tree. He managed to get his hand free and call a few of us to come and get him out. A guy went up in another climber and cut him free. The API wasn't phased at all. This is another reason I now hunt with an API!
The newer Summit's have a "squeeze" type system that I think they came out with new for last year. You can probably see it in a catalogue like Bass Pro or Cabela's.
I am not sure what you mean when you say fold? I know that some of the newer stands do fold flater. My API is all solid and weld construction. The seat portion fits inside the platform section. If I had to guess, the total height of mine measured sitting on a flat surface would be about 12" to 16". One good thing about the API is that the chain system can be pulled in and strapped to the rest of the stand. With the Summit's, the cables form a big "U" shape on the end of the stand that snags on a lot of stuff.
One other opinion on stands it "Keep it Simple." The more moving parts = more noise and places for things to go wrong. On the API, it's two pins on the top, two pins on the bottom and it's attached. I carry an extra just in case I were to drop on. Good luck and hope this helps.
One other thought. Check out a local shop and see if they have these stands or others for you to see and play with. Just don't take my word for it. You are the ultimate one that will need to be happy with your purchase. It just doesn't matter what I think if you aren't happy. One other brand that is EXPENSIVE but a good stand is called "Lone Wolf.' They use cast aluminum to keep wight WAY down but the price is WAY up. It is a stand that I will look into when I look to replace my API, but that is a few years down the road!
