Ice/snow tires
Old Jan 5, 2012 | 10:15 AM
bethanyc23's Avatar
Default Ice/snow tires
anyone know about studding or screws for atv tires. which is better? I have honda 400x and am planning on being out on the lake. Also do the tires need tread bc I have a crap pair of tires with almost zero tread. Would they work?
Old Jan 5, 2012 | 10:27 AM
TLC's Avatar
TLC
If the tires are worn and almost bald you could try studs then load the tires up with "slime" so they do not leak air out the stud holes. Screws need thick tire lugs to bite into and even then they may fall out after enough riding and wheel spinning.
Maybe studs and a tube in the tires may work also. Put the least amount of studs that will do the job the front tires do not need as many studs, just enough so you can steer.
Sounds like a fun idea though, good luck.
Old Jan 6, 2012 | 08:50 AM
BioWare's Avatar
Toxic Ryder
Welcome
Old Jan 11, 2012 | 11:24 AM
treveiger's Avatar
What about chains?
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
