eiger not starting with push button
Old Nov 6, 2013 | 09:49 PM
coconutandcheese's Avatar
Default eiger not starting with push button
hi there forum. I am a newbie. I have a 2006 eiger. when I try to start with the electric start, I get nothing but clicking at the relay. I hear nothing at the starter. I pulled the starter and through 12 to it and it works. but when I try the electric start I get zip......I don't get it. I also tried to just throw a straight 12 directly to the starter while in the atv and it at least made noise but wouldn't turn over. I can, however, pull start it. any help out there will definitely help. he said if I can get it to run, it's mine!! thanks for your time.
Old Nov 7, 2013 | 07:32 AM
TLC's Avatar
TLC
Usually if you eliminate the starter that leaves the starter solenoid.
Old Nov 7, 2013 | 03:12 PM
BioWare's Avatar
Toxic Ryder
Welcome
Old Nov 7, 2013 | 03:22 PM
is there a solenoid? I am used to working on cars and trucks and the solenoid is on top of the starter. the relay clicks, so that is a sign it works. thanks
Old Nov 9, 2013 | 07:38 AM
sdm24's Avatar
yes there is. follow the positive cable from the battery. It runs to the solenoid. I believe it is under the seat.
Old Nov 10, 2013 | 10:06 PM
VTQuadrunner's Avatar
Welcome to the forum!
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
BEEFKING69
Jun 17, 2015 12:38 AM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
sinurgy
Apr 28, 2000 02:33 AM
