Atv wont start
Old Jul 29, 2016 | 01:33 PM
Cody overholts's Avatar
Default Atv wont start
I have what I believe is a kazuma 110cc quad . Motor ID GY6. I have replaced everything on it brand new. Starter..solenoid. .plug wire...key switch...battery...cdi box...it is getting spark and gas but with just turn over but will not start. I checked the timing and it is in time. I need help.
Old Jul 29, 2016 | 02:32 PM
Welcome to the forums.
For help with your Kazuma try posting about the issues it's having in the Chinese Quad part of the forums.
Old Jul 30, 2016 | 07:16 AM
410Customs's Avatar
Off Road Builderaholic
adjust the valves
seriously the valve lash will get so tight on these they will not start. Need to check intake and valve clearance at TDC compression stroke
Old Aug 1, 2016 | 07:17 AM
scootergptx's Avatar
Supersock
Hired Gun!
Old Aug 1, 2016 | 03:56 PM
DirtDevil101's Avatar
Compression???...This falls in line with 410Customs' post
Does it fire on SF (starting fluid)??
How do you know it's getting spark & fuel (is plug wet/did you arc to frame?)
Old Sep 4, 2016 | 12:05 AM
Atv mech's Avatar
Try taking the air filter off put one hand over rear of carburetor and whirl engine hold throttle open about 1/4 to 1/2 you should feel it trying to suck your hand and get fuel make sure it's not blowing fuel back could be your choke not working properly.
LostKeyboard
Apr 26, 2016 08:26 AM
LostKeyboard
Apr 9, 2016 04:31 PM
Brandon Taylor
1) Engine problems..
8
Apr 1, 2016 07:37 AM
Lora Holland
Feb 6, 2016 09:43 AM
