400ex Ticking and Metal Shavings
Old Apr 3, 2017 | 11:04 AM
DirtDevil101's Avatar
You mean you did a ring swap only...I've personally never gone down that path...
Now that you have it running again would you be willing to try & isolate the ticking? Using a solid metal rod against the engine & against your ear will help you determine if in the bottom end, cylinder or valves.
Only suggesting because the shop is going to cost you a ton to rebuild it...
There are LOTS of vids (one of several above) to help guide you...
I guess I'm to stubborn & cheap to give up and let the dealer have it...
Old Apr 3, 2017 | 01:26 PM
Quad450's Avatar
I noticed the tick coming from the top end with the cam on the right front (if sitting on the bike). I just needed a couple days away from the bike really. I got my YZ450 running and my Raptor this weekend so I'm going to pull that 400 back in and take another look before I hit my Polaris Xpress. Once I get into the top end I will post some pictures and possible video link too actually so you can see what I'm seeing. Four eyes are better than two, especially when I don't know what to truly look for. I'll keep you posted.
Old Apr 3, 2017 | 02:51 PM
Read up on this...2 major causes are cam timing guide/tensioner and tappet wear.
Read that getting the tensioner in correctly requires a trick...or the "T" can get stripped...hopefully a vid will cover this.
I'd replace the tappets regardless...they should be cheap...
