turbo trx250x
Old Dec 23, 2017 | 06:23 PM
cr250r 03's Avatar
Smile turbo trx250x
so i have a 1991 trx250x i built a spacer for the cylinder to bump down the compression so i can run a turbo on it does anyone have any experience with this i am very good with motors but not jetting and tuning does anyone have some advice im only gonna run about 10psi max which will give me a 12.65:1 compression ratio which i know is safe i will also run it on race gas 110 octain
Old Dec 26, 2017 | 07:34 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the Honda forums here. Hope they can get you set up right. Sounds like it will be a pretty quick little machine.
Old Dec 26, 2017 | 02:47 PM
hydrex's Avatar
It's kind of tricky putting a turbocharger on a gas motor, unless you can tune it. Also is there a turbocharger small enough to work? I just turbo charged my Arctic Cat 700 cc diesel. I used a Mitsubishi TD 02 Twin Scroll. Quite a big job, btw. PM me if you need help.
1BADRAPTOR
20
Oct 23, 2005 04:16 AM
ScoobyDFW
Feb 5, 2003 11:59 PM
Ian2
Sport Quads
Apr 28, 2000 12:19 PM
dmahr
Mar 30, 2000 11:16 PM
fourtraxx5
Feb 25, 2000 06:01 PM
